Forfatter Emne: Woody boiler 30kw MOUSE STAIRCASE  (Læst 2961 gange)
Offline didier
« Dato: Mar 06, 2010, 12:01 »
at hedestoker they show the complete set I have installed:
Scotte 24kw burner with a woody 30kw boiler (with mouse staircase).
At HEDESTOKER they show efficiency for:
Virkningsgrad ved 16 kW: 94,0 %
Virkningsgrad ved 30 kW: 90,0 % ( der skal tilkøbes musetrapper)
MY QUESTION:
why less effiency with 30kw and mousetrap ?
NEXT QUESTION:
What is the use for the MOUSE TRAP, i have this thing installed in my boiler and i wonder what would happen if i get them out of the boiler and try to run the boiler without the mousetrap?
thanks a lot for any help.
i am only looking to get rid of those halfburned black pellets symptom..
Offline Frank_rasmussen
  • Respekt optjent: +23/-31
Sv: Woody boiler 30kw MOUSE STAIRCASE
« Svar #1 Dato: Mar 06, 2010, 17:06 »
High kW = more energy and air = harder for the boiler to absorb = lower efficiency.
I think that the mouse traps make the smoke (= energy) stay longer in the boiler. This will also lower the chimney temperature
« Senest Redigeret: Mar 06, 2010, 22:00 af Frank_rasmussen »
Offline didier
« Svar #2 Dato: Mar 06, 2010, 21:13 »
Frank,
youre explanation seems very reasonable and I do understand this.
For the moment i will firstly try the blower settings and leave the mousetrap.
You never know maybe my high consumption came from a BAD MOUSETRAP and the MOUSE eat all of my PELLETS.... ;D
« Svar #3 Dato: Mar 06, 2010, 22:01 »
Sorry about my bad translation  :) Mouse trap should have been mouse staircase.
Offline didier
« Svar #4 Dato: Mar 06, 2010, 22:37 »
No problem Frank, I was just kidding around
My english is allso not the best but at last we can conversate that's the main thing  ;)
