Forfatter Emne: Tilføje flere værdier i grafen i Pellmon  (Læst 14376 gange)
Offline msa
« Dato: Okt 27, 2019, 15:09 »
Kører Pellmon på Raspberry PI tilkoblet min Woody 6.89 styring.
Det kører fint og meget stabilt, men jeg vil gerne have flere værdier tilføjet i grafen.
Helt specifikt mangler jeg:
Boiler_return_temp, flow og hot_water_temp.
Værdierne vises jo fint på system image, så data må jo findes i Pellmon et sted.
Er der nogen der kan hjælpe med dette ?
Martin
Woody 16kw, version 6.89, kompressorrens, 60l Metro VVB, Pellmon via RPI, 136m2 radiatorvarme.
Offline motoz
  • Respekt optjent: +18/-0
Sv: Tilføje flere værdier i grafen i Pellmon
« Svar #1 Dato: Nov 06, 2019, 14:50 »
Look in your configuration file /etc/pellmon/conf.d/database.conf
this section: https://github.com/motoz/PellMon/blob/3e2511ada9e2cd5715c5c9ad67f45a41ef8d82f3/src/conf.d/database.conf.in#L14
Kode: [Vælg]
# Here you choose which data items to write to the database #
# These are good for a scotte V4/5/6 burner
d01 = power_kW
d02 = boiler_temp
d03 = chute_temp
d04 = light
d05 = oxygen_desired
d06 = oxygen
d07 = power
d08 = smoke_temp
d09 = indoor_temp
d10 = outside_temp
You can add anything you want to have in the database (to store old values for generating the graphs) here. For instance:
d11 = boiler_return_temp
You can also remove stuff you don't use, for instance if you don't have a lambda sensor you could change d05 = oxygen_desired into d05 = boiler_return_temp, and so on.
The default database has room for up to 15 data items, that can be changed here: https://github.com/motoz/PellMon/blob/3e2511ada9e2cd5715c5c9ad67f45a41ef8d82f3/src/conf.d/database.conf.in#L90
, but note that if you do change that, then you also need to delete the old database and let pellmon recreate it (which is not fun if you have a lot of history saved).
I didn't notice your question until now, hopefully this can point you in the right direction.
