Forfatter Emne: Woody  (Læst 13126 gange)
Offline egon
    • egon.net.ee
Woody
« Dato: Okt 16, 2009, 13:59 »
Can someone comment this Woody graph. Is it normal that light goes under 10 so many times. In what range the light should be and what I can do about it?
Offline JMB
  • For vildt!
Sv: Woody
« Svar #1 Dato: Okt 16, 2009, 15:14 »
Hi Egon
That is very normal when your boiler only do 10%. Then it is a very small fire and the light is very low.
But there is no problem in it at all as long as the fire does not go out and your Woddy has to start up again all the time
/JMB
16 kw. Scotte med Woody 6.10 styring på Opop 418 kedel. Stokerkontrol v.1.81
Opvarmer 175 m2 med ca. 6 tons
Offline Frank_rasmussen
  • Respekt optjent: +23/-31
Sv: Woody
« Svar #2 Dato: Okt 17, 2009, 10:45 »
Perhaps you could set the Woody on a timer that will shut it down in the day time when you don't need the heat. You could use the timer build-in Woody timer.
Or maybe you could the 'Summer stop'-function in newere versions of the Woody control. To do this you need a extra temperature sensor (10 euro on eBay or even cheaper if you build it your self).
Sv: Woody
« Svar #3 Dato: Okt 18, 2009, 08:42 »
Hi Egon,
As you already know, the drop of light to under 10 in short periods when running 10% power is no problem.
However you might have a problem concerning the regulation loop of the temperature.
Your burner is reacting very aggressively on even small changes in the boiler temperature.
It looks like your setpoint temperature for the boiler is about 60 degrees, and small changes in the area of 3-4 degrees, changes the power to go from 10% to 40% in a short periode.
This looks like a too high P-value in the PID-regulation parameters.
Especially under low utilization you will see this problem .
What is the setting of your PID-parameters?
Offline egon
    • egon.net.ee
Sv: Woody
« Svar #4 Dato: Okt 19, 2009, 08:17 »
My PID-parameters are:
P=2.5
I=1.0
D=1.0
I never changed them. I think these are the default values of the chip.
What values are you recommending?
Sv: Woody
« Svar #5 Dato: Okt 19, 2009, 19:41 »
Hi Egon,
These values sounds not too bad, but I would suggest to reduce all three to something like:
P=1.5
I=0.5
D=0.5
...and see if the curves looks better.
P=2.5
I=1.0
D=1.0
Offline egon
    • egon.net.ee
Sv: Woody
« Svar #6 Dato: Okt 20, 2009, 12:18 »
Thanks the curves are better now.
Sv: Woody
« Svar #7 Dato: Okt 20, 2009, 15:11 »
Hi Egon,
Nice  :)
Could you upload a screenshot of the new curves, just to get an feeling about the change.
Offline egon
    • egon.net.ee
Sv: Woody
« Svar #8 Dato: Okt 21, 2009, 07:18 »
You can look my live curves here: http://www.blackpoint.pri.ee/pillefyr/
Sv: Woody
« Svar #9 Dato: Okt 21, 2009, 18:10 »
Hi Egon,
I still think your burner is reacting very aggressively on even small changes in the boiler temperature.
I did a calculation from the data on your graf-page and found:
Teoretical power low is  5.3 KW and high is 29,6 KW.
That is a high power for a normal house, and it looks like your burner is fas too big for your need.
Wich size burner do you have ?
Have you ever had the burner reduced in power ?
Do you need the high power ?
Offline egon
    • egon.net.ee
Sv: Woody
« Svar #10 Dato: Okt 22, 2009, 07:55 »
I am not sure but I think I have Woody 24KW.
I have OPOP H418 and 150L hot water boiler.
My house is 147 m2.
If you look at those spikes on the graph at the morning and in the evening. Those are generated when the hot water circulation pump is on. When the circulation pump is on (hot water circulates in pipe) I get hot water from the crane immediately and dont have to wait for it.
No I never had the burner reduced in power. Do you think I need to do that? How do you do that?
Sv: Woody
« Svar #11 Dato: Okt 22, 2009, 18:18 »
Hi Egon,
Yes, I think you would have succes with reducing your burner.
From your curves I can see that your average power need is less than 10 % at this time of the year, so I think you are "pulling a small trailer with a big truck"  :)
Reducing the burner is simply to reduce the auger time for low and high, as well as reducing the blower for low and high.
You can read these settings with the aid of your stokerkontrol software.
Have a look under Setup >> Factory and tell me the values for Blower low and Blower high.
Then look under Setup >> Operation and tell me the values for Pellets low and Pellets high.
If I have the values, I can give you a hint to what would be realistic values for lower power.
My house is 147 m2.
Offline egon
    • egon.net.ee
Sv: Woody
« Svar #12 Dato: Okt 22, 2009, 19:52 »
In Setup > Factory I have:
Blower low = 5
Blower high = 20
In Setup > Operation I have:
Pellets low = 9.25
Pellets high = 51.4
Sv: Woody
« Svar #13 Dato: Okt 24, 2009, 08:30 »
Hi Egon,
Just a couple of questions more  :)
I can see that your "Chimney draft" is set to 4, is that correct ?
Is your drag in the chimney so high ?
You don't have a "drag stabilizer" in the chimney ? (like this one http://www.hedestoker.dk/shop/itemdescription.asp?id=1262  nice german manual http://www.hedestoker.dk/content/PDF/Dragex_trækstabilisator_datablad.pdf)
Is your "Auger capacitive / 6 min" meassured to be 1200 g or is it just factory setting ?
Is your combustion (Verbrennung) working well ?
Blower low = 5
Blower high = 20
Pellets low = 9.25
Pellets high = 51.4
Offline egon
    • egon.net.ee
Sv: Woody
« Svar #14 Dato: Okt 24, 2009, 18:46 »
I dont now I never changed it.
Citér
Dont now that either.  :-[
Citér
No.
Citér
It is measured.
Citér
I think so.  ???
