Forfatter Emne: How to measure screw capacity?  (Læst 3891 gange)
Offline egon
    • egon.net.ee
« Dato: Sep 24, 2009, 14:15 »
In the manual it says:
Unplug the burner and force-run the auger until pellets start to come out of it, continue for 15 minutes.
Then weigh the amount of pellets after 360 seconds and enter the result into the controls as the capacity of the auger.
But I don't understand how to force-run the auger?
I tried to press and hold the up arrow on the control box, but nothing happens.
Can someone guide me how to do it?
Sv: How to measure screw capacity?
« Svar #1 Dato: Sep 24, 2009, 15:47 »
Hi Egon,
To start the continuous run of the auger, do the following:
Switch off power supply
Press and hold the arrow-up key while switching on power supply
Keep arrow-up key pressed, until the auger starts to run
Now the auger will run until you press arrow-down key.
« Senest Redigeret: Sep 24, 2009, 15:52 af MHES »
Offline egon
    • egon.net.ee
« Svar #2 Dato: Sep 25, 2009, 09:37 »
Thank You for the help.
