Forfatter Emne: Min. temperature -300,00 in usage data  (Læst 8697 gange)
Offline egon
    • egon.net.ee
« Dato: Sep 16, 2009, 07:41 »
Why I have min.temperature -300,00 in Stokerkontrol usage data?
http://www.blackpoint.pri.ee/pillefyr/textusage.html
If I understand it correctly, its when Stokerkontrol cant get the reading of outdoor temperature then it saves it as -300,00?
This is ok, but can you exclude the -300,00 from the min.temperature readings and show the real min.temperature in usage data?
Sv: Min. temperature -300,00 in usage data
« Svar #1 Dato: Sep 16, 2009, 19:59 »
Think we have a little bug there, if you for some reason cannot connect to the site you get your temperature from even if it is just once, it will take the -300 (which in fact means N/A) and insert it as the lowest temperature.... we will look into a way to filter these out, hopefully already in the upcoming 1.78 release.
« Senest Redigeret: Sep 16, 2009, 20:00 af BoinkUser »
Offline egon
    • egon.net.ee
« Svar #2 Dato: Nov 27, 2009, 13:58 »
I see you are working on ver 1.81. Do you plan to fix the -300 (N/A) problem to?
« Svar #3 Dato: Nov 29, 2009, 14:19 »
Hi Egon
Yes, we will fix this.
Regards Jens
