Forfatter Emne: Min. pellets dose  (Læst 15491 gange)
Offline shun
Min. pellets dose
« Dato: Feb 22, 2017, 13:27 »
Hallo!
What does "Min. pellets dose" (Stokerkontrol---Auger) mean?
How it works?
Sv: Min. pellets dose
« Svar #1 Dato: Feb 22, 2017, 14:57 »
Hallo!
How it works?
It is the smallest docis  the auger can provide.
When the power increases, the amount too.
Offline shun
« Svar #2 Dato: Feb 22, 2017, 15:47 »
Thank you Michael!
What happens if I manually increase/decrease this value?
« Svar #3 Dato: Feb 22, 2017, 16:06 »
The auger adjust the "running time" for each dosing according the actual power %.
But you can run in the situation (depending on the amount the auger feed per 360 sec) where the shortest dosing is so short in time, that the auger really doesn't feed at all.
If you then increase the minimum dosing, you prevent this to happend.
However, it will also result in the auger to run with longer time-interval's when the actual needed dosing is below the minimum dosing you set.
Therefor the minimum dosing should be as low as possible, while the minimum dosing is still large enough to do a functional dosing.
Regards
Thank you Michael!
Offline shun
« Svar #4 Dato: Feb 22, 2017, 16:22 »
Regards
More or less clear.
Thank you very  much Michael!
