Forfatter Emne: Desired CO2  (Læst 3094 gange)
Offline mrxswe
  • Mikael
Desired CO2
« Dato: Feb 15, 2016, 19:40 »
Some questions regarding the adjustment of the burner.I have adjusted CO2 to 12-13% at 50 and 100%. The burner is a new NBE 20kW that is set to 3.5-16kw (Fan type FLO85)
Desired CO2 at 100% = 12-13%. 50% = ????? 10% = ?????.
Mikael
Sv: Desired CO2
« Svar #1 Dato: Feb 15, 2016, 20:38 »
Hi,
Normally it would be something like:
 - 16% O2 at 10% power
 - 12% O2 at 50% power
 - 8% O2 at 100% power
...but it depends on how much air leakage the boiler has.
The above values fits a 100% air-tight boiler.
Mikael
« Senest Redigeret: Feb 15, 2016, 20:40 af MHES »
Offline mrxswe
  • Mikael
Sv: Desired CO2
« Svar #2 Dato: Feb 15, 2016, 21:05 »
At 100% I have o2 = 8,9 CO2 = 12.25% ppm >100
At 50% I have o2 = 9.4 CO2 = 12.54% ppm >88
At 10% I have o2 =15,2 CO2 = 6.8% ppm<400
The boiler is new so it should not leak so much.
Sv: Desired CO2
« Svar #3 Dato: Feb 16, 2016, 05:31 »
Hi,
A little high O2 at 100% power and a little low O2 at 50% power, but if the combustion is fine it is OK  ;)
Bedt regards
