Forfatter Emne: V7/V13 UDP protocol client in python  (Læst 160884 gange)
Offline barbaz
Sv: V7/V13 UDP protocol client in python
« Svar #45 Dato: Dec 04, 2018, 21:56 »
I've mikrotik access point and I run dump directly on them. I've tried sniffing using the mac of the phone as a filter, then I sniffed all traffic... no broadcast at all :( In fact the app didn't find the boiler on local lan but only as "remote".... It will find the boiler only if connected on the wifi lan "generated" by the boiler itself (RTB-XXXXX)
In the meantime I'll try to dump the traffic when attached to this SSID.
Offline motoz
  • Respekt optjent: +18/-0
« Svar #46 Dato: Jan 21, 2019, 16:56 »
I'm still waiting for some info from NBE about what changed in the protocol... not much we can do without that.
Offline barbaz
« Svar #47 Dato: Jan 21, 2019, 18:10 »
By my side i'm not able to connect to the RTB-XXXXX wifi network :(
do you know the default password?
They told me that it's written on the boiler itself but it doesn't work....
Offline motoz
« Svar #48 Dato: Feb 11, 2019, 07:46 »
Barbaz, can you test the nbetest client from this branch https://github.com/motoz/nbetest/tree/testing/v13 ?
Seems as the v13 controller flips out when it receives a valid frame with a source port higher than 9999, in the testing/v13 branch the source port is set to a free port between 8483 and 9999. The v13 also requires a correct serial number to respond so this is also set in the discovery frame. Would be good to know if this works as I can't test it myself.
« Senest Redigeret: Feb 13, 2019, 07:20 af motoz »
Offline barbaz
« Svar #49 Dato: Feb 16, 2019, 12:46 »
Hi motoz! sorry for delay but I didn't have the possibility to test it.... it works! that's fine!
Thank you very much, it seems that you find the problem and now the boiler didn't disconnect anymore.
Some examples:
Kode: [Vælg]
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxxx get
settings/
operating_data/
advanced_data/
consumption_data/
event_log/
sw_versions/
info/
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxx get  info
Traceback (most recent call last):
  File "client.py", line 81, in <module>
    args.func(args, proxy)
  File "client.py", line 27, in getfunc
    l = proxy.get(args.path)
  File "/home/osmc/nbetest-testing-v13/protocol.py", line 135, in get
    response = self.make_request(9, '')
  File "/home/osmc/nbetest-testing-v13/protocol.py", line 176, in make_request
    self.response.decode(data)
  File "/home/osmc/nbetest-testing-v13/frames.py", line 171, in decode
    raise IOError
IOError
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxx get  settings
settings/boiler/
settings/hot_water/
settings/regulation/
settings/weather/
settings/weather2/
settings/oxygen/
settings/cleaning/
settings/hopper/
settings/fan/
settings/auger/
settings/ignition/
settings/pump/
settings/sun/
settings/vacuum/
settings/misc/
settings/alarm/
settings/manual/
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxx get sw_versions
  File "/home/osmc/nbetest-testing-v13/protocol.py", line 129, in get
    response = self.make_request(10, '')
    raise IOError
IOError
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxxx get sw_versions
  File "client.py", line 80, in <module>
    with Proxy(args.password, PORT, args.address, args.serial) as proxy:
  File "/home/osmc/nbetest-testing-v13/protocol.py", line 75, in __init__
    data, server = self.s.recvfrom(4096)
socket.timeout: timed out
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxxx get advanced_data
as you can see it gives IOerror getting info, advanced_data and sw_versions ... sometimes it returns socket timeout instead
settings seems to work correctly:
Kode: [Vælg]
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxx -p xxxxx set settings/regulation/boiler_power_min 30
OK
osmc@osmc:~/nbetest-testing-v13$ python client.py -a 192.168.12.22 -s xxxx get settings/regulation/boiler_power_min
30
thank you a lot!!!!
Offline skovfyr
« Svar #50 Dato: Maj 17, 2019, 18:57 »
Newbie question - do the use of get commands in the python client affect the data collected to StokerCloud or will that run unhindered despite using the client ?
/Allan
Offline motoz
« Svar #51 Dato: Maj 19, 2019, 13:05 »
It won't affect stokercloud. The connection to stokercloud uses a completely different way of communicating.
Offline skovfyr
« Svar #52 Dato: Maj 19, 2019, 23:28 »
Great - thank you for the answer - confirms my belief, I think (I expected the Stokercloud to be some kind of push from the controlbox) - it was the mentioning of seqnum (or noseqnum) in some of the client calls that got me a little worried that something might not be stateless ...
Offline motoz
« Svar #53 Dato: Maj 20, 2019, 07:23 »
Yes there is a sequence number, as far as I know the controller doesn't use this field in any way apart from returning it in as is in the response.
PellMon checks that the returned sequence number is the same as the one sent and regards the frame as invalid if not (see https://github.com/motoz/PellMon/blob/3e2511ada9e2cd5715c5c9ad67f45a41ef8d82f3/src/Pellmonsrv/plugins/nbecom/nbeprotocol/frames.py#L177 ), but the nbetest client doesn't check the returned seqnum at all. It's up to the client to increase the sequence number for each request or not, nbetest sends a random number since it is a stateless client.
The protocol is not completely stateless in the controller. Setting changes are rsa encrypted (since they require the password to be transmitted), and that takes a long time to process in the controller (seconds for each frame). To make this work there is an option to set a client specific key for the much simpler xtea protocol. The key is set using rsa encryption, and then the controller remembers the key for that client and can use it to decrypt xtea encrypted setting changes much faster. Due to this the controller only supports a limited number of clients, four or five maybe as I remember it. I think it just drops the key for the oldest 'connection' when the table if full.
The nbetest client doesn't support xtea encryption at all since it is stateless, supporting it would require the xtea key to be stored somewhere. Pellmon sets an xtea key when it connects to the controller and periodically changes it here: https://github.com/motoz/PellMon/blob/3e2511ada9e2cd5715c5c9ad67f45a41ef8d82f3/src/Pellmonsrv/plugins/nbecom/nbeprotocol/protocol.py#L320
The stokercontrol protocol is actually only the controller polling stokercloud with http GET with current data in the query string and commands and setting changes in the response payload.
Offline skovfyr
« Svar #54 Dato: Maj 21, 2019, 00:11 »
Hi Motoz
Thank you - very comprehensive answer  :)
/Allan
Offline Alfie
  • Black Star med v7.0651
« Svar #55 Dato: Jan 30, 2025, 15:09 »
Hello :-)
5 years ago, I had it working with the python client. With newer versions of Windows and python, I can only get, the get functions to work. If i want to use the set function, it comes up with failures. I tried a lot of things, but my knolege of python is around zero. Can i be lucky, that someone here knows to help me further with this issue?
