Forfatter Emne: PellMon på Raspberry  (Læst 196904 gange)
Offline motoz
  • Respekt optjent: +18/-0
Sv: PellMon på Raspberry
« Svar #135 Dato: Jul 31, 2016, 13:22 »
Answered in the other thread...
Offline motoz
« Svar #136 Dato: Mar 12, 2017, 18:26 »
New PellMon release v0.7.0 with lots of new functionality since 0.6.1:
https://github.com/motoz/PellMon/releases
The new NBEcom plugin has been running with my V7 controller since last spring without a single issue or lost connection so it's very stable. The release contains a ready made system image and an example database configuration for the V7 controller which makes it as easy to use with a V7/10/13 controller as with a V4/5/6.
https://github.com/motoz/PellMon/wiki
Offline Hemhems
  • Respekt optjent: +5/-0
« Svar #137 Dato: Jun 30, 2017, 11:48 »
Great, I'm glad you find it useful! You are the first PellMon user with a 4.x box that I know of so it's nice to know that it works as intended. Just ask if there is anything.
Hi Motoz!
I am really happy with the solution, and it is nice and easy to setup :-)
My box was not prepared for serial interface, so at first I had to insert a MAX232 capable chip, before I could communicate with it - afterwards it was a piece of cake, to install the PellMon/RPi interface  :D
I would really like to change the descriptions/text on the webpages that PellMon uses, but as I'm not the Linux-Superuser (never had used Linux at all before), I can't figure out where the files are placed - can You please help me sort it out??
Thank You, for the great work developing PellMon!  :D
Regards Kristian.
Skal man stadig konvertere rs232 til usb, eller kan man bare skrælle et usb kabel og montere RX/TX og stel til +- og stel på usb kablet..
Ville prøve samme setup på min 6.76 styring, men gætter nok på at interfacene mellem usb og rs232 ikk kan snakke sammen umiddelbart.
Rasp pi 3 - plus noget konverter og usb kabel og så er man vel kørende?
Scotte 10kw - V7 - BS20 Kedel
Smedegaard Simflex 25/60
3 Vejs ventil - Vølund QMC100
« Svar #138 Dato: Jun 30, 2017, 18:49 »
RS232 og USB er to vidt forskellige ting, så man kan ikke "skrælle" et USB-kabel og forbinde til et RS232 interface  ;)
Det kræver lidt elektronik at lave konverteringen  ;)
Helt fundamentalt er RS232 et "point-to-point" system, mens USB (Universal Serial Bus) som navnet siger er et BUS-system hvor der kan være flere enheder på samme kabel.
Hi Motoz!
Regards Kristian.
Offline Hemhems
« Svar #139 Dato: Jun 30, 2017, 21:55 »
Ja dumme spørgsmål bevares jo normalvis korrekt.. :D
Nå nu fatter jeg hvad der skal til, men at finde delen i europa er så en anden sag...
« Senest Redigeret: Jun 30, 2017, 22:42 af Hemhems »
Offline kivi
  • Respekt optjent: +7/-0
« Svar #140 Dato: Jun 30, 2017, 22:56 »
Arh, det er vist ikke et stort problem.
https://www.av-cables.dk/usb-til-seriel-adapter/
Ole
Offline Hemhems
« Svar #141 Dato: Jun 30, 2017, 23:05 »
Det kan laves på flere måder, synes mest om et stik og breakout board på printet..
« Svar #142 Dato: Jul 01, 2017, 10:12 »
Der findes ikke dumme spørgsmål  ;)
...vi lærer ved at spørge og undres  ;)
Go' jagt
Offline Uff82
« Svar #143 Dato: Feb 02, 2020, 18:25 »
Hej alle,
Ved godt tråden er gammel, men er der nogle der har en pellmon installations image.img eller ligne til at ligge de vil dele?
Jeg har hart det satup på min Scott v6.22 . men sdkortet døde og fik aldrig lavet en backup af det. og nu kan jeg bare ikke få den til at virke igen:-(
Offline kivi
« Svar #144 Dato: Feb 02, 2020, 18:33 »
Du kan bare hente installationsfilen her.
https://github.com/motoz/PellMon/wiki/How-to-install-PellMon
Ole
