Forfatter Emne: 0 Lx on photosensor  (Læst 11309 gange)
Offline rekuper
0 Lx on photosensor
« Dato: Jan 10, 2008, 07:03 »
Hello,
could you help me, please? I have momentaly the problem probably with photosensor and there is seen on the control box screen such a message like "no fire" or "0lx" even if the bioler is running and temperature is growing up. Sorry for english, I am from czech republic.
Regards
Jiri
Offline magnussen
Sv: 0 Lx on photosensor
« Svar #1 Dato: Jan 10, 2008, 18:31 »
ok i wil try..
sometimes there can be some dirt on the sensor... try clean it first.... if that doesent help.....  i think it is defekt...
Søren
Offline Jannich
  • Respekt optjent: +41/-5
    • NBE
« Svar #2 Dato: Jan 11, 2008, 04:36 »
Hello,
Regards
Jiri
Hi Jiri
You can contact www.opop.cz , they have spareparts for the burner,
You can allso call me to find out what is wrong the photo censor.
Regards Jannich
0045-96892632
Pillefyr:
RTB 10kW
Solvarme:
Solcelle system:
Installeret aug. 2012
Offline Hans
« Svar #3 Dato: Jan 11, 2008, 17:44 »
Sometimes this photo sensor is broken because of an open circuit at the crimp between the photo sensor-element and the wire inside the photo sensor house.
Open the sensor house, check for open circuit from the sensor-element to the wire.
A solder iron will do the repair unless the fault is right at the sensor-element, then it is "new sensor".
/Hans
Woody 16 kw, Opop 418 kedel, ESBE TV25 60°C termostatisk ventil og Wilo Stratos ECO pumpe.
Opvarmer ca. 88 m2 (heraf 19 kælder, og 8 fyrrum i garagen)
Interface fra http://www.stokerkontrol.dk
DragonFire interface.
