Forfatter Emne: Eksterne snegl motoren altid under spænding  (Læst 2810 gange)
Offline max251osb
« Dato: Jul 31, 2011, 18:22 »
Hi,
4,99 Scotte min kontrol synes at blive brudt?
Jeg havde allerede to gange en tilbagevenden til den smeltende brandslange, mens den fotosensor.
Motoren i den eksterne skruen er i kraftig vækst, selv om han ikke arbejder.
Kablet fra controlleren til eksterne skruen er under spænding.
Kan du ordne det? eller skal jeg udskifte controller?
undskyldning  min dårlige Danske , jeg bruger Google Translator
my Scotte 4.99 control seems to be broken?
I had already twice a return to the melting fire hose and the photo sensor.
The engine of the external screw is booming, even though he is not working.
The cable from the controller to external screw is under tension.
Can i fix it? or do I replace the controller?
Scotte 16 KW, 4.99, DOR
200 qm
Sv: Eksterne snegl motoren altid under spænding
« Svar #1 Dato: Aug 02, 2011, 10:19 »
Hi,
Sounds like you have a serious problem with the controller.
I would suggest to take contact to the local supplier for service.
Hi,
Offline max251osb
« Svar #2 Dato: Aug 02, 2011, 20:16 »
yes, apparently the relay is faulty.
I'll order as replacement a version 6.00 Controller, 'm looking for the best price.
 maybe it holds longer than 3 years than my old 4.99 Controller ,
 and he has a lot more functions.
Robert
200 qm
