Stokerforum
Powered by Nature
Velkommen,
Gæst
. Venligst
log ind
eller
registér
dig.
1 Time
1 dag
1 uge
1 måned
Altid
Nyheder:
Følg NBE Production A/S på
Facebook,
se hvad vi laver
Hjem
Hjælp
Log ind
Registrér
Stokerforum
Interface
Interface til varme systemer
Stoker kontrol
Pause or not to pause?
Udskriv
Sider: [
1
Gå ned
Forfatter
Emne: Pause or not to pause? (Læst 5008 gange)
egon
Prof
Respekt optjent: +2/-0
Dato:
Mar 02, 2011, 06:02 »
Currently I dont use pause in my configuration, after ignition and power it stops the lighthouse.
Should I use the pause function and how long it should be?
Logget
xkfc
Top of the pop
Respekt optjent: +175/-24
Sv: Pause or not to pause?
Svar #1 Dato:
Mar 02, 2011, 14:29 »
Hi Egon
It's rather strange that your pilletburner is not running all the time, when you use 20kg per day.
I use 25kg per day, and my pilletburner is running 25-30%
Usually it is poor economy to use the pause function.
Yours sincerely
Kenneth
Logget
egon
Prof
Svar #2 Dato:
Mar 03, 2011, 05:55 »
When outdoor temperature is lower than -5C it runs all the time. But when outdoor temp. is warmer it stops at night because I keep lower temp. in house at night. And when outdoor temp. is 0C or warmer it may stop at any time when the selected boiler temp. is achieved.
You think it's strange behavior? Why?
How it should behave then?
Logget
xkfc
Top of the pop
Svar #3 Dato:
Mar 03, 2011, 06:30 »
It's probably just because I dont' know the size of your burner.
24KW?
Logget
egon
Prof
Svar #4 Dato:
Mar 03, 2011, 06:44 »
Yes it's 24KW.
Logget
Udskriv
Sider: [
1
Gå Op
Stokerforum
Interface
Stoker kontrol
