Forfatter Emne: Help with StokerKontrol 1.181 and Scotte  (Læst 7474 gange)
Offline MunichMan
« Dato: Jun 29, 2010, 04:33 »
Could anyone please post oder mail me screenshots of the parameters on the StokerKontrol 1.81 pages "Extras" and "Oxygen"
I didn't write down the original values before playing around....
Thanks
Wolfgang
Wolfgang.Denz@gmx.de
Sv: Help with StokerKontrol 1.181 and Scotte
« Svar #1 Dato: Jul 01, 2010, 22:51 »
g.Denz@gmx.de
Hi Wolfgang
Here goes for Scotte 4.99c which is similar to 4.99j according to these parameters:
Extras/Diverse
Chimney draft=3
Max. drop shaft temp.=80
Gain p=2,5
Gain i=0,25
Gain d=10,0
Fine tune low=10
Fine tune hight=30
Cleaning interval=10
Cleaning time=4
Powerdown time=2
Autocalulation=yes
Oxygen
oxygen control=no
Oxygen level low output=12,0
Oxygen level high output=5,5
Blockingtime=30
Oxygen correction low=10
Oxygen correction medium=20
Oxygen correction high=30
Correction time=30
Gain P=0,75
Gain I=30
Have a nice evening.
Regards Jens
Offline MunichMan
« Svar #2 Dato: Jul 03, 2010, 08:45 »
When I want to reach the desired temperature of 75° I have to set the Gain-parameters to the following values:
Gain-P : 9
Gain-I : 5
Gain-D: 1
Otherwise as soon as the temperatuire comes close to the desired temperature (close measns reaching 65°) the burner decreases power to 60-70% and the temperature quickly drops under 60°
If I use the above mentioned values my oxygen-values are very fast changing from under 6% up to 12%
Oxygen-control is disabled at the moment.
Where is the error, or what can I do?
Thanks for help
Wolfgang
Offline Frank_rasmussen
  • Respekt optjent: +23/-31
« Svar #3 Dato: Jul 03, 2010, 09:34 »
You can post graphs from StokerKontrol on this forum and I am sure people will have views on what to do.
Normally increasing the I-gain will make the temperature eventually come closer to the wanted value.
All heating systems are not equal in the sence that you can find PID-values that will fit everone.
Tuning PID-values can take time and you will have to make compromises....but using an interface like StokerKontrol you will get results  :)
