Forfatter Emne: StokerKontrol 3.0 alpha1  (Læst 21317 gange)
Offline DennisRN
  • Respekt optjent: +17/-3
    • Phoenix 16kw
Sv: StokerKontrol 3.0 alpha1
« Svar #15 Dato: Jun 01, 2010, 14:33 »
Fint - tak  :)
Phoenix 16kw med det hele
Styringsnr.: 59091
VVB prioritering 140l.
Nu med RTB Grill! :-)
Offline egon
    • egon.net.ee
Sv: StokerKontrol 3.0 alpha8a
« Svar #16 Dato: Jun 02, 2010, 13:33 »
If I run the StokerKontrol 3.0 alpha1 or alpha8a I get this:
What is wrong?
Offline BoinkUser
  • Respekt optjent: +83/-4
« Svar #17 Dato: Jun 02, 2010, 16:22 »
What is wrong?
Hi Egon
You are probably running Windows XP? You need StokerKontrol 3.0 alpha8b to be compatible with Windows XP, the earlier 3.0 versions are not 100% compatible.
Try that and let me know if its ok.
Regards Jens
Offline egon
    • egon.net.ee
« Svar #18 Dato: Jun 03, 2010, 07:45 »
Hi Egon
Regards Jens
No I am running StokerKontrol 3.0 alpha8b on Windows Home Server (Windows Server 2003). So its not compatible with Windows Server 2003.
Offline BoinkUser
« Svar #19 Dato: Jun 03, 2010, 09:29 »
Please send an email to info@stokerkontrol.dk, and we can take a look at it.
Offline egon
    • egon.net.ee
« Svar #20 Dato: Jun 04, 2010, 13:11 »
How can I set the web graph to show outdoor temperature on its own axis?
Offline BoinkUser
« Svar #21 Dato: Jun 04, 2010, 16:37 »
You cant in the current release.
