Frank,
after 6 months of bad burning and cleaning people do get impatient
The ash in the ashtray today is gray to darkgray, the burnergrate seems to be better, slightly saturated but not like before, I swiped it of this noon, may be I should have left if and checked back after 2 days. that's what I am planning now with these new settings.
I did the weight test again this noon and I had 1050gr. I have changed High feed to 46 now.
The settings for the blower are now set just like the settings for Siver Alu blower: 35 for high.
No black smoke from chimney, chimney draft? really I don't have a clue how to measure this and I believe my salesmen does not have the tools for it neither.
So I do live at the coast about 2 miles from the sealine in a house in open surroundings, as always in these area's we have lot's of wind but I don't know about the chimney draft so I have to guess about this.
I do have the Woody boiler and no OPOP so I don't have any of those handles.
http://www.hedestoker.dk/content/Woody%20træpillebrænder/Woody%20version%206.pdf
this looks totally like my installation but I have the 4.99 controller with the LEDS.
I have the Woody 30kw boiler, scotte 24kw burner with 4.99 controller, this needs to heat a old house with around 200m².
I have 11 heating elements in the house, no roof insulation, but that is the first thing we do went it becomes a little better weather and i have double glass windows everywhere.
I also have a ladomatpump and a double watertank, 800l for heating and 150l for warm water.
For example:
it is now 3° outside and the heating is on inside, the elements are hot everywhere, completely hot so there's no airbubles in the heating elements or tubing.
I ask 23° in the house and only reach 22° maximum after heating for about 16hours...this seems not sufficient to me.
Before this we had a huge consumption with a gasboiler (24kw) that is true but we could reach 24° easily in this house with same conditions, but it reached 23° easily and more quickly.
The consumption we had If I do remember good was around 12000m³ of gas pro year (very expensive, i was almost ruined) So this is why we decided to install the pellets system.
I was told it was running very smooth, little ash to clean every 14days and so on, the usual salesmen talk.....It just gave me trouble, cold and lot's of cleaning work and I am stuck with it myself to have the problem solved...
I wonder also if I needed that buffer tank from 800l, to me it is only another 800l to heat up before i get any warmth into my heating elements.
The burner runs about 18hours a day and comsumes 60kg a day, it becomes expensive also and does not heat up the house as it should be like the gasboiler did before..
Anyway i plan to get the salesmen to court because i am almost used up with this boiler system and my yard looks like a coalmine with all those ashes and half burned pellets everywhere around the yard.
thanks,
Didier
