Forfatter Emne: Compressor replacement  (Læst 7975 gange)
Offline LucyandJean
« Dato: Nov 15, 2022, 15:59 »
Hello all,
I have a NBE RTB 30 boiler. When I tried to restart ir this winter, the controller shut off after a few minutes. After investigating further, I found out that the fuse on the controller blows everytime the compressor tries to start. It looks like my compressor needs to be replaced.
My question is how can I replace the compressor and connect it to the relay? Also, I live in the US, is it OK to use a 120V compressor?
Thank you!
Sv: Compressor replacement
« Svar #1 Dato: Nov 15, 2022, 19:48 »
I don't think it would be a problem with a 110V compressor
But.. I would recommend you contact a local dealer, he is probably more familiar with the current being 110v
