Forfatter Emne: RTB16 V7 Failed Main PCB?  (Læst 1892 gange)
Offline AMRTB
  • Alan in Madrid
« Dato: Dec 31, 2020, 13:20 »
Hello
I write to you from Spain.  My RTB16 (V7) has failed.  The differential (Earth leakage trip) trips off.  I can see that water has dripped from the chimney onto the top of the boiler, and there are watermarks inside the control box. I don't see obvious signs of catastrophic damage to the PCB (I'm an electronics engineer).  I will try to clean the PCB in case it is just a case of something conductive washed onto the PCB in the area of the MAINS 230V input causing the problem.
The problem is that the Spanish distributor is on holidays until 4 January. After that, I don't know how long they would take to help me (6 January is the main Christmas holiday here).  I live in the mountains, and the RTB is my only source of heat.
There is a UK online store, but they show the main PCB and extension PCB out of stock.
I don't have a login for nbe-shop.dk  How do I get an account there?  How long would it take to receive a new PCB?  Approx cost? (it doesn't show on the website without a login).
RTB 16kW, 500L Buffer + Instant HW, Weather compensation, Underfloor heating 110m
Sv: RTB16 V7 Failed Main PCB?
« Svar #1 Dato: Dec 31, 2020, 13:58 »
Hello
Fine if you can clean and dry the print.
Everything is closed down until January 4th.
If the print is defective, it may be fastest to contact a local dealer.
Here is a map showing dealers.
http://stokercloud.dk/dealermap/
Maybe there is someone near you who has parts in stock.  :)
